Fuel Leak
Old Oct 6, 2013 | 03:55 PM
SammySoto's Avatar
ML430, 2001
Exclamation Fuel Leak
I have a 2001 ML430. In which I have fuel leak in the supply line. I recently changed the three main lines and filter. And yet I still leak which is the connection dela pump and feed line. A long time ago I'm trying to repair my ML since I'm short of economical resources. Before this happened to use a gasoline additivo which I read in the linings use is not recommended because it causes problems. And I think that was the cause of mine but not now where else to look for this problem. What I found is that I have liners to change the sensors but which. If I can give a help I thank.
