need help!!!
Old Nov 18, 2003 | 11:25 PM
VTBenZO's Avatar
ML320
need help!!!
I have installed a carlsson quad exhaust system on my ml320 2000, it looks amazing, i will try to post a pic, but when the car is on drive, it causes a rattle sound which is very loud and annoying..................can anyone tell me what to do, anyone from Evosports know??? also, lately there have been this metal like resonance in the right side of the dashborad or maybe behind the gauges.......anyone experienced such thing before??
Thank you
Old Nov 20, 2003 | 12:16 PM
ML320AMG's Avatar
1998 ML320 + 1985 AE86
if you have exhaust installed .... check if they left out the grounding for exhaust.
as for the resonance behind the dash. I have the same problem and it sounds like it's in the airbag. If you hold on the steering wheel tight .. the sounds seems to go away. if thats the case it could be some broken/loose part around the cruise control lever. Get a set of torx screw driver and open up the area behind the steering wheel area.
Good Luck
D.
