2002 Ml 320. Problem!! please
Old Feb 10, 2014 | 03:00 AM
mk25's Avatar
Ml 320
I have 2002 Ml 320. Mileage/ 748777 Km.
Drives fine, but I have noticed that on the meter where is shows mileage, as i start the car it beeps and shows tool sign then -400. Now after 2 weeks it is showing -700. It shows this as I start the car only for 10sec then back to normal and shows the mileage. Can any one help with this? What could it be?
Please see attached pic.
Thanking you all for your concerns.[/IMG].
Old Feb 10, 2014 | 09:06 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
What you are seeing is a reminder that your Flexible Service System (FSS) is over due by 400 miles. This was only necessary while under warranty and can now be used to set your oil change intervals.
All of this information and many other helpful bits of info. are found in your owner's manual. Please get one.
File Type: pdf
Old Feb 10, 2014 | 11:01 PM
DrX's Avatar
DrX
2002 ML320, 2003 A160
Oil change intervals were officially extended to 20,000 km, as long as you use an approved MB sheet 229.5 oil (e.g Mobil 1 0W-40) and a polyester fleece filter. If you have these it's safe to allow the FSS counter to overrun by a few thousand kms.
