Newbie Questions
2). Also anyone installed Alpine (pop up) NAV/DVD, how do you like it and what was the cost. Installer suggestions in So California??
3). What should the tire pressure for a comfortable ride on the 17 std wheels? [I know its an SUV].
Thanks for your inputs.
2. if you have MCS equipped ML, you can add the NAV unit. It is a do it yourself job if you are interested.
3. Tire pressures should be listed in you door frame or on the gasoline filler door. I have a 320 so I am not sure if they are the same.
i am interested in learning more about this. i have 2002 ml320.
also, another question. do u have to have dealer install the timeport or v60.
does anyone know of anybody in philly area who installs these things in these vehicles outside of dealer?
1. You will need a set of radio keys (about $7) to pull out the MCS.
2. Remove the top and the fake front behind the LCD.
3. Drop in the Nav unit
4. Replace the top and connect the prewired coax to the roof gps antenna.
5. Turn on the unit, enter the radio password, and the unit should be active. Takes a few minutes to orient itself after it locks on to the satellites.
