how to change oil & Tranny fluids?
Old Feb 27, 2014 | 01:36 AM
rohanpatel14's Avatar
ml55 amg
I have 2000 ml55 amg and i can not find DIY for this oil and tranny fluids change. I did search but couldn't find nothing.
Old Feb 27, 2014 | 12:09 PM
ml55 amg
29 viewed and no help!! Please help me!
Old Feb 27, 2014 | 06:54 PM
art_arev's Avatar
2003 ML55,2007 ML63
For your oil change find No6 on the picture. That is you oil pan. You will find a drain plug on the side of the oil pan. Unscrew the bolt let the oil drain. Remove the oil filter & replace. Screw the drain bolt back. Fill with oil.
The PDF is for transmission flush.
NOTE this is for ML320 with 722.6 transmission. Make sure things are similar on ML55 before you proceed.
Attached Thumbnails how to change oil & Tranny fluids?-r-i-bottom-part-oil-pan.jpg
File Type: pdf
