98 ml 320 issues
Old Feb 28, 2014 | 11:04 AM
Bbrian82's Avatar
98 ml 320
98 ml 320 issues
Ok first issue changed the battery then the suv wouldint start
Cranks over but doesn't sound like its really starting
I don't have the stock cd player in it so don't know if it throwing off codes
Would a code scanner show me that
Ok then was reading that owe hold the lock button on key hit unlock 5 times this deprogrammed my key had to cause door locks worked befor I did that now it doesn't any ideas here
Old Feb 28, 2014 | 04:17 PM
vmystikilv's Avatar
Range Rover
Radio is irreverent. You need a OBD II reader to find the code. Im guessing fuel pump or bad crankshaft position sensor
Old Feb 28, 2014 | 05:29 PM
art_arev's Avatar
2003 ML55,2007 ML63
When did you change the battery? Did you change it because the car wouldnt start? Give as proper info in details.
Do the key resyncing properly
