Brake pads
Old Nov 28, 2003 | 11:24 AM
JAD's Avatar
JAD
Brake pads
The wife's '99 ML 430 is going to need some new pads soon. Any suggestions for some good low dust pads? Does Mintex, Hawk, Pagid or Porterfield make pads for the ML? Can anyone give me some suggestions? Thanks!
Old Nov 30, 2003 | 05:45 PM
howvood's Avatar
2000 ml320
brake pads
This past spring I installed Wagner Thermoquiet pads and shoes on my Jeep. They have been amazing as far as improved braking and lack of any noise. I haven't got to the point of replacing the pads on my ML yet but will be installing them on my son's ML this week. The part numbers are on Wolfgang's site.
Old Nov 30, 2003 | 05:46 PM
ViKTORiOUS's Avatar
W209 - W163
I have Porterfields to remove the brakedust from my wheels, they work great, my wheels barely have any brake dust on them! I suggest you get these, you can get them from www.formymercedes.com
Old Nov 30, 2003 | 05:58 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Re: Brake pads
I would recommend Pagid or Mintex. The Porterfields still dust considerably, often make lots of noise (even if you adapt the Brembo shims to them), so you may as well go for something more reasonably priced.
I also found that the Porterfield pads for the larger MLs (2000+ ML430/ML55) had a slightly larger pad, so that if you do not replace the rotors at the same time, they may not fit into the wear grooves for a while.
-s-
Old Nov 30, 2003 | 08:12 PM
aaaaa5star's Avatar
use the Rotex Gold
I have used Rotex Gold Kevlar pads on my benz, they dont put out andy dust, bout them from brakeworld.com
-mike
Old Nov 30, 2003 | 08:28 PM
ViKTORiOUS's Avatar
W209 - W163
http://www.brakeworld.com/catalog.as...=items&catid=2
Okay, my Porterfields give off a little brake dust, and Im getting new wheels soon, so i want to tottally eliminate the dust, does Rotex have applications for the 02 models? They dont seem to have them online, hows AXXIS? Thanks!
