ML320 oil will not drain!
Let car idle for 30 minutes and tried to drain. Nothing. Today purchased a quart of engine flush. Idled as on directions, cold engine, five minutes, still no oil from drain plug. Siphoned excess oil out of dip stick tube to bring level back to normal.
Oil siphoned out is warm. Oil reservoir, where drain plug is is cold.
What next?
NC
You drained your front diff like this owner did: http://www.benzworld.org/forums/w163...ing-trans.html
As Art said, you need to buy the correct gear oil from your MB dealer and refill the diff before you drive anywhere. Otherwise you could destroy the diff. Alternatively, you can use any oil in the "90" column of this page: http://bevo.mercedes-benz.com/bevolisten/235.0_en.html
