Your typical ML ESP/BAS light problem
Old Sep 10, 2014 | 02:21 PM
Moosedes-Benz12's Avatar
2001 ML320
Hello, I have a 2001 Mercedes Benz ML320 and I have this consistent problem of my ESP/BAS light staying on. Once in a blue moon it will turn off and the system will work properly, like when I take a corner in a quick manner it will slow down the car and the ! light flashes during that process. Also when the system is working and the ESP/BAS light is off, I can turn of ESP by a switch in the cabin, as it should. Otherwise the ESP/BAS light is always on and the system does not operate at all. What should I do? Do I need a part for the esp system? Can I fix this myself? Do I need a Mercedes Benz tech to diagnose the problem first?
Old Sep 10, 2014 | 04:54 PM
art_arev's Avatar
2003 ML55,2007 ML63
You need to scan your car with a pro level scanner & post the codes
Old Sep 10, 2014 | 05:12 PM
2001 ML320
Ok, do I need to get that done at a Mercedes shop or can I go to any other shop? I heard that only Mercedes specific diagnostic scanners work.
Old Sep 10, 2014 | 05:27 PM
art_arev's Avatar
2003 ML55,2007 ML63
Any pro level scanner will do. You don't need to go to the dealer.
Old Sep 10, 2014 | 05:34 PM
2001 ML320
When you say pro scanner you mean those red (or at least what I think I've seen to be as red) diagnostic scanners they plug into a port in the driver's foot well?
Old Sep 11, 2014 | 07:45 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
A professional grade scanner is large and held with both hands. Those in the link below are Snap-On, simply shown as a example, but it does not have to be that brand It also must be able to read European codes.
https://www.google.com/search?hl=en&...51.fWKa9a16tn8
Old Sep 11, 2014 | 09:41 PM
2001 ML320
Thank you very much! I'll try to get that done.
