P0141 and P0161
Old Sep 17, 2014 | 01:01 PM
TRMNATD's Avatar
1999 ML320, 2004 ML500, 2003 SVT Cobra, 1986 T Type, 1987 Grand National, 1969 Camaro SS396/X66
P0141 and P0161
99 ML320, 200k mi.
Have 2 codes show up the other day. I cleared them and as soon as it goes into closed loop it throws the codes. P0141 and P0161.
Anybody have any ideas. I find it hard to believe that both rear O2 sensors would go bad at the same time. I looked under the truck, wires look good (looks like original sensors).
Also checked the fuse at #19 was good, and ground near brake booster is tight.
Thanks for any help
Old Sep 18, 2014 | 02:28 PM
art_arev's Avatar
2003 ML55,2007 ML63
Your car is 15 years old. It is very much possible that your post CAT sensors are cooked. Maybe you had 1 bad sensor & didn't know about it & the second one has gone bad as well. Is there a problem with the car or you just did a routine scan?
Old Sep 18, 2014 | 10:34 PM
TRMNATD's Avatar
I replaced both sensors, and so far so good. I used the search and many people did that, and still got the same codes.
Drove 100 miles today and no cel.
Thanks for the help!!
