Hesitation accelerating from stop
Old Nov 23, 2014 | 06:50 AM
ML 500 mz's Avatar
2003 ML 500
Replaced plugs/wires (both w/OE Bosh) to correct hesitation, only noticed accelereating from full stop. New plugs/wires have greatly improved the situation, but a slight hesitation still exists. Anybody experience similar issue?
Thanks in advance,
mz
Old Nov 23, 2014 | 08:31 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
You probably have a dirty Throttle Actuator. If it is not clean as in the photo it must be removed to be cleaned, as it faces the rear of the engine.
Remove the air intake pipe and then have a look at it by using a mirror. If it is dirty then remove the 4 Torx bolts and clean inside and out with Throttle Body Cleaner. Do not use Carburetor Cleaner.
Attached Thumbnails Hesitation accelerating from stop-throttle-actuator-98-00.jpg
File Type: pdf
File Type: pdf
Old Nov 23, 2014 | 02:11 PM
ML 500 mz's Avatar
2003 ML 500
I'll give it a try & let you know if issue resolved.
Thanks for your help,
