2005 ML500 Battery Dies after 2-3 days
Old Nov 23, 2014 | 02:37 PM
Dritschel's Avatar
Ml500 S430 4Matic
I have a 2005 ML500 and after 2 to 3 days, the battery is dead. I have a new Interstate battery, CCA 720, CA 900, RC 176. When I put a multimeter inline with the battery cables, I only see a draw of 0.29 amps. If I check the volts on the battery, every hour, seems to lose about 0.02 volts per hour.
Old Nov 29, 2014 | 02:36 PM
Dritschel's Avatar
Ml500 S430 4Matic
Does anyone have this issue? Or know if it is fixable?
Old Dec 1, 2014 | 07:03 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Since there are two fuse boxes to check, follow the steps below. But first close all doors and make sure that no lights remain on. Then...............
1. remove the key from the ignition.
2. open hood.
3. open right front door and with a screwdriver throw the latch to simulate the door being closed. Wait to see that the overhead lights go out. Wait 20 mins. before proceeding so that all the modules "go to sleep".
4. then go to the underhood fuse/relay box and follow the directions in the video. Make note of which fuse does not pass the test.
5. then do the same for the right side kick panel fuse box.
Post back with what fuse/s # is faulty.
Remember to pull the outside handle on the door before you close it.
Attached Thumbnails 2005 ML500 Battery Dies after 2-3 days-door-lock-throw.jpg   2005 ML500 Battery Dies after 2-3 days-2014-12-01_065533.jpg
Old Dec 14, 2014 | 09:57 PM
Dritschel's Avatar
Ml500 S430 4Matic
Thanks,
Been having a problem with my other car and haven't gotten to it yet.
