ML270 diesel unidentified T bleed contraption
I snapped mine at the t piece when replacing my thermostat ( very common during this procedure) and had to temporarily bypass that branch with a hose and jubilee clips bridging the hole just leaving a straight through feed from the low pressure pump to the high pressure pump with the branch you are talking about completely disconnected and the car fired up (After a fair bit of cranking) and ran fine for a week before I could buy a proper replacement ( the replacement is a full moulded 3 ended piece with the T piece.
Hope this helps even if it is a little late.
Assuming it works there are pictures of the T piece and the bleed branch when installed on the vehicle, along with pictures of the temporary bypass mod to get the car going after the T was broken during the thermostat change (note this mod could be done better with a straight through adapted and fuel hose but this is all I had at the time.
There are also pictures of the fully molded replacement part (with the part number shown on the bag, and also a picture of the hose retaining clips for under the highpressure pump- worth getting a couple of these before changing the hose as they get brittle and the clip snaps- these are essential to keep the fuel pipes from fouling on the auxiliary belt - only 3 or 4 mm clearance even with the clips.
Hope this works and helps.
Moz
