LED swap issues
Old Dec 10, 2014 | 12:39 PM
bjp's Avatar
bjp
2000 ML430
LED swap issues
I have started to switch the interior bulbs out to LEDs. The footwell lights in the front work as well as the ones under the doors when you open them. I'm having issues with the "map" lights in the overhead console and the overhead lights over the back doors. My issue is that they turn on for a split second and then turn off. I bought a set of CAN-BUS LEDs hoping this would take care of this, but it didn't. Normally the lights turn on when you open the doors and stay lit for a little while and then fade to off.
Has anyone else ran into this issue or know of what could be causing this?
Thanks for your time!
Brian
