ml320 transmission fluid
Old Jan 1, 2015 | 09:11 PM
urbs007's Avatar
ml320
need assistance. 1999 ml320 purchased 1 month ago with 130,000 miles. dont know maintenance history. was cheap ($2,000) and was recommemded by a ml320 owner who also owns a 2006 r-500. made a tranny dipstic and get no reading on stick. vehicle warmed up and level. after warming up i smell what seems to be oil burning . pan is wet. transmission shifts fine, although a little late when cold (20 degrees F) when i bought it, i did an oil change with valvoline synthetic 10-w-30. level remains same after 2 weeks. what do you guys recommend? cannot afford dealer maintenance.
Old Jan 2, 2015 | 03:29 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Your first mission is to get the proper dipstick.
http://www.ebay.com/itm/Mercedes-Benz-722-6-Transmission-Fluid-Dipstick-Tool-1231-/151526527927?hash=item2347af53b7&item=151526527927&pt=Motors_Automotive_Tools&vxp=mtr
The second mission is to find exactly where the leak is coming from: pan, trans. pressure hoses, front seal, etc.
Old Jan 2, 2015 | 08:31 AM
urbs007's Avatar
ml320
Mercedes Benz 722 6 Transmission Fluid Dipstick Tool 1231 | eBay
I think first mission was accomplished sufficiently for my intentions. I was trying to determine if the fluid was burnt or dirty. I made 2 dipsticks, 1 was 1/16" stainless braided cable. The other was about 1/8" throttle cable. They both bottom out when inserted into dipstick tube. No fluid is on either cable when checked. Can the vehicle be driven ? If it cant be driven, would my next step be spraying down the gasket and pilot bushing area with brake clean to find leak? I'm very concerned about no fluid reading as I've been driving this vehicle on the highway at 80 mph with apparently no fluid in the pan. Would the cables I'm using is there any way they couldn't be bottoming out?
thanks
Old Jan 2, 2015 | 04:18 PM
art_arev's Avatar
2003 ML55,2007 ML63
If you blow your tranny it will cost you much more then a dipstick. Buy the proper dipstick & measure the tranny oil properly. If there is no oil don't even think of driving the car. And the car must be running when measuring tranny fluid level.
So, go back to mission 1, then to mission 2
