2002 ML 500 error P0120
Old Jan 12, 2015 | 12:51 PM
comptronix's Avatar
2002 320 CLK 2002 ML 500
Ok let me start with I backed my car up the other day and when I put it in drive it wouldn't go forward nor backward , problem is that the engine does not react my me giving it gas with the pedal or at the cable under the hood.
After reading my code it said P0120 so I replaced the throttle/ pedal position sensor reset my codes but I am still net getting a response from the engine.
Any suggestions ?
Old Jan 13, 2015 | 06:08 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
What make scanner are you using? Does it show you live data?
Old Jan 17, 2015 | 12:36 PM
comptronix's Avatar
I have a bluethooth OBD II plug in and use Torque on my phone.
and yes it can read live data
Old Jan 17, 2015 | 01:26 PM
I have no idea what live data you scanner shows, but warm the truck up to operating temp. and compare the readings to the chart below, concentrating on the Pedal Value and Throttle Values.
File Type: pdf
