OIL HIGH warning flashing
So slightly high oil level would cause the car to stall & not start?
The oil level is supposed to be midway between the Min & Max lines on the dipstick. If you are above the MAX line, drain off 1/2 qt.
Are you able to start and run your truck at this time?
