2004 ML350 Brake warning light on with ABS,BAS/ESP, 4-ETS
Old 03-07-2015, 01:38 PM
art_arev's Avatar
2003 ML55,2007 ML63
Joe, it seems your voltage regulator on the alternator is overcharging, hence all this codes.
Old 03-07-2015, 02:25 PM
jerseyjoe10's Avatar
2004 ML350
Art, OK I will replace alternator and try again.
Thanks Joe,
What should be the max alt voltage at idle?
Old 03-07-2015, 02:48 PM
art_arev's Avatar
2003 ML55,2007 ML63
NO!!! Not the alternator!!! It is the voltage regulator on the alternator that is a known culprit. At idle without load & without revving close to 13,8
Old 03-07-2015, 03:05 PM
2004 ML350
OK but I have a alternator shop that I will buy a remanufactured alternator that will have a new regulator.... Or should I just change the regulator? Is it easy to change?
Thanks joe
Old 03-07-2015, 03:40 PM
art_arev's Avatar
2003 ML55,2007 ML63
Just the regulator. Its very easy when the alternator is out.
Old 03-07-2015, 04:18 PM
2004 ML350
It is a bosch alt
Old 03-07-2015, 04:28 PM
  #32
art_arev's Avatar
2003 ML55,2007 ML63
Bosch part # of the regulator?
Old 03-07-2015, 06:37 PM
  #33
2004 ML350
Art,
I replaced the Alternator and the regulator now charging system is charging at 14.4 at idle. ABS lights are still on and will not reset. when I do go to reset it the red brake lights comes and first and then the 3 yellow lights come on ABS BAS/ESP & EST Do not know what to check next?? Thanks Joe.
Quick Reply: 2004 ML350 Brake warning light on with ABS,BAS/ESP, 4-ETS
