fogs switch light
Old Jan 22, 2004 | 11:46 AM
pointman's Avatar
a car that can't do the throttle reset.
fogs switch light
when you guys had your fogs activated... and you turn the fogs on, does alight turn on on the actual switch? cause ive heard its supposed to pight.
Old Jan 22, 2004 | 01:28 PM
JimB's Avatar
2000 ML320/'03 C320WZ
I wish we know
what year is your ML, bur Yeah the headlight should be on before you can used your dash switch, by MB default. Unless you don't want to use you OEM dash switch.
Old Jan 22, 2004 | 01:31 PM
pointman's Avatar
i have an 00, and 01, 04. i know you have to turn the headlights on first, but i am talking about the MB dash switch...when the fogs are on should the dash switch light up? (when you turn on the rear fog, a light turns on...same idea).
Old Jan 22, 2004 | 01:42 PM
smurtaza's Avatar
'03 C32 LET Stage I
Fog light Dash warning
I have '00 ML 320 with fog lights activated via the button. There is a green warning light on the instrument cluster that is suppose to turn on when fog lights are active, but they do not for me. I was told by the SA that this feature is only support for Factory Installed fog lights like in ML55. I have heard from some other sources that there is a way to enable this feature but may be my SA did not know about it.
Old Jan 22, 2004 | 02:13 PM
JimB's Avatar
ahopeter
yes that suppose to lit up when your fog lifhts are on, rear and front use the same dash switch the color for the front is a green dot light and amber on the rear.
amurtazza, your SA must be new or lack of knowledge about his job The should activate it thru laptap. MIne, I have to cover it with black tape because it is way too bright for me. I can still see the green halo though.
Old Jan 22, 2004 | 04:52 PM
pointman's Avatar
cool, thanks for letting me know.
Old Jan 22, 2004 | 05:05 PM
JimB's Avatar
u r welcome
