Service
Old Feb 14, 2004 | 04:23 PM
VTBenZO's Avatar
ML320
Service
Question,
I have a 2000 Ml320, it is due to service in 500 miles, the warranty has run out, how much should i expect to pay for an 'A' service, one wrench is showing? Does the Dealer have to do it?
Thank you
Old Feb 15, 2004 | 04:27 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
If I remember correctly, A is just a minor service (oil change, filters, check over everything)...but that doesn't mean it runs cheap. From the dealer, service "A" may run around $200. Service "B" can run $400+ I think (atleast my service did).
Old Feb 15, 2004 | 11:44 PM
VTBenZO's Avatar
ML320
Thanks for the reply.......................is the dealer the only one that can perform an A or B reply, or can any mechanic do it?
Old Feb 16, 2004 | 09:39 AM
GDawgC220's Avatar
'05 A4 1.8TQM6
If you go to like a garage, they may not have the tools (computers, actual tools for some parts on MB's) to do the job right. And they can't reset the computer on the cluster (most places can't).
What would be a good idea is either the stealership or find a independent MB mechanic who knows what he's doing.
Old Feb 21, 2004 | 12:27 AM
Pancham's Avatar
ML 320 MY2000, C320WZ MY2004.5
Find a local German Car specialist...MLGod your input?
My 2000 ML320 also expired a couple of weeks ago so I asked the same question to a local German garage; they only do MB and BMW. I recall the mechanic saying that they could do an A service for $200 less since that was only an filter/oil changed and they could reset the console because they have the tool. I even asked him if that required a tune-up and he said that the system monitors itself and reports problems; so tune-up wasn't necessary for A service which makes me think that I could do it myself but I won't be able reset the indicator. He did mention that B service is could be between $300-$400. This garage charges $75/hr while dealer charge $98/hr.
I hope ML God will read this so he can itemize work being done at A & B services.
TIA
Old Feb 21, 2004 | 12:47 AM
GDawgC220's Avatar
'05 A4 1.8TQM6
Re: Find a local German Car specialist...MLGod your input?
TIA
He is right between the differences between service A & B. A is the single wrench, which is the minor service. "B" is the major service, which esscentially is a "tune-up" with more parts replaced.
$75 is not bad for a independent. Better than the dealer anyhow. My independent MB dealer charges $60/hour.
Old Feb 21, 2004 | 08:46 AM
azinn's Avatar
2014 RX 350 F Sport, 2007 Scion tC, 2000 ML 430 Money Pit Finally Gone! Oh Happy Day!
FYI , your owners manual tells you how to reset the computer yourself.
Old Feb 21, 2004 | 01:02 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
If your independent told you he has the tool to reset the service indicator I would stay away from him. There is no tool necessary, just read the instructions in your manual.
Old Feb 21, 2004 | 01:12 PM
Kar don's Avatar
Mercedes-Benz
Re: Re: Find a local German Car specialist...MLGod your input?
who is ur mb mechanic, i might start using him for the ML.
Old Feb 21, 2004 | 04:59 PM
VTBenZO's Avatar
ML320
I just got my B service yesterday, I was going to let a local mechanic do it...........but it seemed he didnt really know what is he doing when asked me "do you feel the engine needs a tune up?", so i opted for the dealership, it wasnt too bad, they gave me a discount, they also did the state inspection for me, it all added up to $368..........it is a payment, but i know the dealer did it......more reliable.........I would suggest to let the dealership take care of it.........................
Old Feb 21, 2004 | 05:10 PM
redcoupe's Avatar
11 ML350
It's just a oil change, with a quick inspect of the car.
And if you wnat to reset the fss:
-Make sure the drivers door is closed
-The key is turn on with the engine off
-Push the black button the left in the insturment cluster twice quickley, release.
-Quickley turn off the key and press and hold the same black button and hold
-And turn the key back on.
-Hold the button until it changes.(Takes a few seconds)
If it dosen't work the first time try again.
Brian
Old Feb 21, 2004 | 09:50 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
Re: Re: Re: Find a local German Car specialist...MLGod your input?
Hey Ali,
I use "Hatch & Sons" in Wayland. The SA's name is Ed Owen, pretty nice guy, up front with you and all that good stuff.
Their website is "www.hatchandsons.com". They have a c36 for sale on the lot...i know you were looking at a c43 last year. '95 with 62k miles on it. Black, very nice condition!
Let me know if you go there.
Old Feb 22, 2004 | 10:25 AM
ima55r2's Avatar
2018 Mclaren 720s, 2021 Aston Martin DBX
This came off a dealer's website and an experienced mechanic should be able to do them for a fraction of what MB would charge.
Flexible Service System - A-Service
- Change your vehicle's engine oil and filter
- Replace the dust filter in all SLK, CLK, C-Class and E-Class models
- Ensure the warning and indicator lamps, horn, windshield/headlamp
wiper and washer systems, and seat belts are functioning correctly
- Inspect tires and check tire pressure (including spare)
- Inspect brake pad thickness and disc condition
- Check and correct all fluid levels
- Reset your vehicle's FSS counter
Flexible Service System - B-Service
- Replace the dust filter in all SLK, CLK, C-Class and E-Class models,
and in S-Class and SL-Class models without the active charcoal filter
- Replace windshield wiper inserts
- Inspect and rotate tires
- Lubricate and inspect throttle linkage
- Ensure the parking brake, steering play, headlamps and exterior lamps,
warning and indicator lamps, horn, windshield/headlamp wiper and washer
systems, seat belts, and backrest lock (S-Class only) are functioning correctly
- Inspect front axle ball joints and Poly-V-belt
