BAS/ESP indicator light on
Old Dec 15, 2015 | 04:08 AM
esoul16's Avatar
2003 ML350 Inspiration Package
The yellow BAS/ESP indicator light on my dash is on display when the engine is running/i'm driving. I checked the manual and saw all the possible causes for the BAS/ESP light to display. The most likely would be malfunction of the BAS or ESP.
1.) How is the BAS/ESP Checked for malfunction? If this turns out to be true after checking the BAS/ESP, I just want to know ahead of time, is there a replacement part in the car that is responsible for BAS/ESP function? Can this part be purchased aftermarket brand new or can it only be got fairly used.
2.) I am a cautious driver and my brakes are still working fine. If I do nothing about this, is there any critical danger to me and/or the car if the BAS/ESP malfunctioning is not fixed. I read in the manual that the BAS/ESP does not prevent accidents only careful driving does.
Your feedback is highly appreciated.
Old Dec 15, 2015 | 04:49 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
You must have the codes read with a scanner. Look at all the possibilities.
File Type: pdf
Old Dec 17, 2015 | 02:35 PM
Jetpilot718's Avatar
2012 G550, 2018 AMG GTR, 2020 Sprinter 2500
1st common item - brake switch. 2nd, yaw sensor. For me, yaw sensor did the trick.
Old Dec 18, 2015 | 08:19 AM
There is no Brake Light Sw. on 2003-2005 ML's.
