2003 ML500 Oxygen Sensor help
Old Jan 7, 2016 | 12:05 PM
NPLA's Avatar
2003 ML500
I have a 2003 ML500 with Check Engine light on so I got the code and I was told I need "Bank 1 Sensor 2". But I am confused as to the exact sensor part. Could someone please help me out as to the exact part I need? Thanks.
Old Jan 16, 2016 | 04:18 PM
MikeC825's Avatar
ML430 1999
do a search You can get replacements for $32 at www.carparts.com
I am going through the same issues with mine right now.......but am also getting misfire in #1 and occasionally #5 Truck would not start the other day, but just got it going today.
Good luck
Old Jan 17, 2016 | 05:07 PM
S430LUCKDRAGON's Avatar
2003 S 500 4 MATIC , 2001 S 430 , 2003 ML 500
Check for any exhaust leaks first guys i had the same issue with my ML 500 and it turned out to be an exhaust leak , so i wasted 120$ on an 02 sensor i never needed , also the location of bank one sensor two is on the passanger side second 02 sensor down from the engine
