2004 ml350 shifter won't work
Old Apr 6, 2016 | 04:37 PM
Daniel Melusky's Avatar
2001 clk55 AMG 2002 e55 AMG 2001 c240 6speed
so i have this 2004 ml350 in the shop that i can't shift out of park unless i use the neutral safety switch. this model doesn't have the brake light switch and the fuses are fine. i already tried replacing the whole shifter and that didn't work. any ideas? I'm about to chase the whole electrical wire.
Old Apr 9, 2016 | 04:26 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
With the key on, do the three brake lights illuminate when you press the brake pedal?
Also check fuses #15, 16 & 22 in the underhood fuse/relay box.
What neutral safety switch, where is it located? Explain.
Old Apr 11, 2016 | 09:39 AM
the brake lights work and i did check all the fuses. the neutral safety switch is that little flap located on the shifter that you can shove a screw driver down and then you can change the gears freely. I'm going to check the fuses again.
Old Apr 11, 2016 | 10:22 AM
MikeC825's Avatar
ML430 1999
Did anything spill on the console?
Old Apr 11, 2016 | 10:53 AM
who knows probably I've already tried replacing the whole thing. the car has no codes and it drives fine
Old Apr 12, 2016 | 07:37 AM
That is not a neutral safety switch. ML's do not have one. It is simply an emergency release.
Go to the elec. connector at the shifter and with a test light or DVOM, check the following wires:
#4 BROWN for GROUND
#8 BLUE for 12v
#9 GREY for 12v
