ML 270 /2001/ Auto gearbox
Old May 17, 2016 | 12:45 PM
Samar1's Avatar
ML 270 diesel Auto gearbox 2001
Hi there i have ML 270 /2001 Auto gearbox sometimes and mor offen in the morning the gear stuck on one gear randomly not always the same gear and when this happens the tiptronic doesn't change as well and cruise control not working.!!! Switch the car off and start again everything works normal. Any suggestions solutions please. Thanks in advance
Old May 17, 2016 | 05:39 PM
Samar1's Avatar
Originally Posted by Plutoe
Don't waste your time with mumbo jumbo----spend the money and get the car scanned!!
All will be clear!!
PS:My guess is that you need a new conductor plate!!
I had it scanned the computer showed there is no wrong. Was searching online for this issue. Found simple way to fix it and i have tried it. It's seem good improvement on the gearbox gear changing. But because the problem not happening all the time have to give it some times to be sure if the problem solved. (seat inside the car locked all the doors by remote put the key in the ignition and switch on first switch that's doesn't turn the dashboard lights on then kick the diesel escalator in full for one minute. Then switch off the ignition open the doors start the car its done ☺ hope will work. so far its seem some different in the gear changing I'll update that in couple days if it's solved the problem for me
