Headlight, Door locks and Door panel Question
Ok couple of questions.
1st the easy one.
Where can I find Door panels my driverside panel is pretty well ****ed. The handle broke and the clips broke that hold the panel on the door and now every time you close the door the panel catches and you have to open the rear door and push the panel in in order to open the door.
#2 Where can I find headlights? When I bought the car the passenger side head light was busted from an accident by the P.O. but the light still worked the light no longer works so while I'm replacing the buld might as well replace the whole unit.
#3 The door locks are acting funny. The rear driverside hasn't worked since we bought the car when you unlock the car it clicks 3 time but either way it never locks. Now just today the passenger front doesn't lock and when you click the key fob to lock it it too clicks 3 times and refuses to lock. and now the sensor that locks the doors when you drive above 15mph is constantly activating while in stop and go traffic. How do I fix this?
1st the easy one.
1 and 2---Look to the national scrappers such as LQK!!
3--find an indy with DAS diagnostic equipment or equal who can interrogate the central locking system and advise quickly on the fault----else my guess is you have low tire pressure!!
Why would low tire pressure cause this?
You were already given the answer in the other MB forum that has a much larger readership / source of experts for ML's. Why are you posting here? Makes no sense.
And, no, low tire pressure has absolutely nothing to do with machine gun locks. The person who suggested that is clearly not aware of this infamous W163 problem.
Wayne has a reading comprehension problem--read my advice on #3 and then the word "else" followed by comedic response.
However wayne is correct your issue has nothing to do with tire presure or any othe comment that was not produced by DAS diagnostic test results!!
Forget the HS experts---get the car scanned!!
I made both posts at the same time. I didn't post there and get an answer and then post here.
