02 ml500 Fuel Pump
02 ml500 Fuel Pump
Hey I have an issue w my car starting. I turn the key and it just cranks and doesn't turn over. Checked the fuel pump and turns out that it isn't getting power. The connector pin under the rear seats and carpet has a green wire that doesn't supply power. Is there a wiring diagram for this? I must've cut/short a wire on accident when I installed new speaker wires.
What fuse # have you checked?
Check both contacts at fuse #13 in the R/S kick panel fuse box for 12v, while you are cranking the engine.
