BAS. ABS, ESP
Old Jul 26, 2017 | 10:35 PM
hp8300's Avatar
ML320
Question BAS. ABS, ESP
Hi all, i replaced the "Brake Pressure Regulator Assembly" and was wandering if i need to code to the ECM.
2001 ML 320
Old Jul 27, 2017 | 06:31 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
What were the codes before you replaced the regulator and what are the codes now?
Old Jul 27, 2017 | 08:28 AM
hp8300's Avatar
ML320
Bas,ABS,ESP
Dundee thank u for ur reply,
I do not have the report from before the replacement anymore but i did attach a recent diagnostic report.
Hope that helps
File Type: pdf
Old Jul 27, 2017 | 01:09 PM
I can only assume that you changed the pressure regulator because of prior codes.
Code C1000 requires that you replace the ESP Control Module which is housed in the underhood fuse/relay box.
Remove the covers to the box, pull up the module and copy the number down, 163 545 xx xx, and buy a used one and install.
Then clear all codes and see which ones return.
File Type: pdf
Old Jul 27, 2017 | 02:18 PM
hp8300's Avatar
ML320
Bas,ABS,ESP
I will have physical check
I will post an update ASAP
Old Jul 27, 2017 | 02:46 PM
hp8300's Avatar
ML320
Does this ESP Control module need to be coded to the car ?
Old Jul 27, 2017 | 10:25 PM
No, if it is used.
