No Throttle response
Old Aug 11, 2017 | 10:40 AM
garyl1812's Avatar
W163 Ml 270CDI
I have a 2004 270ML. When starting the car first time it starts and runs fine. once up to operating temperature and the car is turned off it displays the EPC light and a few seconds later the oil light but oil is good. The accelerator does not respond at all. Open the bonnet and leave it for an hour and away it goes again.
Diagnostics show various codes relating to high/low voltage but nothing specific
Any ideas?
Old Aug 12, 2017 | 04:29 AM
garyl1812's Avatar
W163 Ml 270CDI
No throttle response
when plugged in by breakdown it displayed 6 faults including Accelerator position sensor 1 power supply.
Accelerator position sensor 2 power supply. Engine oil sensor voltage low. Power supply for sensors 1 not plausible. Exhaust gas recirculation Less then minimum. Once the car decides to go again all faults can be cleared. Nothing specific as in a sensor bad. All seems to relate to power supply. Alternator has been tested ok and battery good
Old Aug 12, 2017 | 05:40 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
You must scan the car and post the code numbers.
Old Aug 12, 2017 | 01:03 PM
garyl1812's Avatar
W163 Ml 270CDI
The codes are P0100
P1481
p1403
p1403
p1611
p1192
p1222
p1234
Old Aug 13, 2017 | 06:19 AM
The codes are P0100
P1481
p1403
p1403
p1611
p1192
p1222
p1234
Have you cleared the codes and then taken a new trip? Carry the scanner with you and as soon as the problem occurs, immediately read the codes and post them here.
File Type: pdf
