2004 ml350 defroster doesn't work. Please help!
Old Sep 21, 2017 | 09:42 AM
Matt0901's Avatar
2004 ml350
I've replaced the blend door actuator already but still nothing. The defroster would sometimes work for a few minutes then cut out. Any kind of advice or guidance would be much appreciated!
Old Sep 21, 2017 | 11:09 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Is that the reason why you replaced the Blend Door?
Old Sep 21, 2017 | 11:13 AM
Matt0901's Avatar
2004 ml350
That was the only thing that I could find while researching it online. I should have asked on here first...
Old Sep 21, 2017 | 01:58 PM
Remove the cover under the left side Instrument Panel.
Look up to the right and locate the Trans. Control Module and pull it out of the bracket. Then remove the bracket and you will see the Def. Actuator.
Request defrost and watch to see if the actuator moves. If not, it must be replaced.
Attached Thumbnails 2004 ml350 defroster doesn't work. Please help!-actuator-motors-2002-leg-rear.jpg
