Starting on second try
Old Oct 13, 2017 | 03:48 PM
tsilva's Avatar
2002 ML 500
Start on first try may be prolonged or won't start at all. Second try starts right up. Runs like a top once started. I'm thinking it may be either the fuel filter or fuel pump. Any thoughts?
Old Oct 15, 2017 | 03:14 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
If the CEL is not illuminated, then it is probably a fuel issue. Start by purchasing a Fuel Pressure Gauge and attach it to the fuel rail. Then turn the key to pos. #2 and note the fuel pressure reading.
File Type: pdf
Old Oct 17, 2017 | 04:33 PM
tsilva's Avatar
2002 ML 500
Smile Thanks a lot !
I will do exactly that and l let you know what I find out. Thanks again.
