Please identify the black box behind fuse/relay box
Old May 6, 2004 | 10:18 AM
pcy's Avatar
pcy
'14 ML350, '13 C220 CDI, '07 C280, '98 ML320
Hello,
After turning OFF and removing the key from ignition (on my '98 ML320), I hear a motor whining noise. This noise continues for about 3 minutes or so. The noise is coming from the black box that is immediately behind the fuse/relay box (in the engine compartment) on the drivers side.
Anyone know what that box is, what's that noise, or anyone have/had that problem?
Thanks in advance for your comments/suggestions
pcy
Old May 6, 2004 | 10:43 AM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
This is no problem, its normal. What you hear is the E box cooling fan. In addition, the electrical coolant recirc pump wil run after a shut down.
Old May 11, 2004 | 07:21 AM
TheGreat1's Avatar
BMW 328i, 2000 ML320
I concur it just the air pump. It suppose to help with emission. Yes sometime it get on my nerve too. But its a common problem with the ML. Which to ML is VERY common...
Old May 11, 2004 | 08:23 AM
pcy's Avatar
pcy
Thank you guys for your assurances.
pcy
Old May 11, 2004 | 10:59 AM
sosh's Avatar
No, its not the air pump it is a fan as I previously stated.
Old May 11, 2004 | 12:10 PM
pcy's Avatar
pcy
Yes, I agree; it is a fan.
It's just annoying to hear the fan motor whining (albeit faint whine). When the garage is quite, you can hear it prominently.
I raised this question because I wasn't sure whether it's supposed to run even after ignition is off.
Has anyone tried to open that black box and may be oil
the fan motor or something like that (don't laugh)? ;-)
Old May 11, 2004 | 12:27 PM
mbtech208's Avatar
1997 Toyota Tacoma 4x4
When that module box fan really goes bad, you'll know it. It'll sound like a herd of crickets is in the dash when you first start the engine in the morning.
