ML320 starting problem
Then one day it cut off while idling and to this day never started and only cranks.
These are the error codes that came out P0156-O2 SENSOR CIRCUIT BANK 2, P0161 02 SENSOR HEATER CIRCUIT BANK 2 SENSOR 2, P0110- INTAKE AIR TEMP. SENSOR 1 CIRCUIT, P0300 - RANDOM MULTIPLE CYLINDER MISFIRE DETECTED, P0301 CYLINDER 1 MISFIRE DETECTED, P0302 CYLINDER 2 MISFIRE DETECTED.
I was planning on buying a new MAF sensor, Crank Shaft sensor and Oxygen sensors which are four in the vehicle. Please advice me on getting it fixed. (Spark plugs have recently been replaced.)
Thanking You.
It appears that you are having a fuel issue: fuel filter and/or fuel pump. Purchase a Fuel Pressure Gauge and check fuel pressure at fuel rail. Should be 55 psi with key in pos. #2.
If low or no fuel pressure, change fuel filter first.
1. Under moderate braking approaching traffic lights to a stop , the engine faulters , as if wanting to stall, catches itself and then runs fine . Slow braking there's no problem.
2. Under hard acceleration she violently cuts out as if the transmission (automatic) has just jumped out of gear, total loss of revs and accelerator control. There's a 2-5 second delay and all returns to normal ( really dangerous stuff). I'm about to buy a fault code reader as my first step ( would really appreciate any recommendations for which to purchase that will read the Mercedes codes in the $300 bracket) . I'd really appreciate any advice on problems 1. and 2. above please. Regards Nissrolet.
