Coolant Temperatures sensor
Hi, I'm still puzzling over my temp gauge. Not sure if the coolant temperature sensor is defective or not? I have replace this thing before (almost 2 years ago) but when I perform a scan the readings are as followed:
-044 B1 2/2 (Refrigerant pressure and temperature sensor) 6 bar
-045 B1 2/2 (Refrigerant pressure and temperature sensor) 158 degree F.
Base on the scan data 158F translate to 70C. But my temp gauge was at 90C. There is a difference of 20Degree C. Does this mean my sensor is shot? Any comments are appreciated! Thank you
You are confusing the Coolant Temp. Sensor with the Refrigerant Pressure/Temp Sensor, the latter of which has nothing to do with the eng. temp.
I'm not sure if I ask you this, but can you show me the correct procedure to check if both the fans in front of the radiator are working properly by removing the relay and performing jumper. I come to believe that my wiring harness might be damage somewhere in between the connector at the fans and aam modules where the relays and switches are.
I like to know if my radiator is working or not. How do i know if it is working properly?
Lastly, when i'm driving and with AC turn on i can hear my air compressor engaged. It creates a errr sound. Afterwards, this errrr sound continue to be hearing from inside the car while driving. Could it be the bearing on the ac compressor about to be going bad? If so, can I swap the bearing out?
Many Thanks
To mechanically check the fans, first check to see that fuse 44 is not blown. If not, fashion a short jumper wire with spade terminals attached and remove relay K26.
At the fuse box slots where K26 was, insert ends of jumper wire into slots 30 & 87 and the jumper wire must make contact with a silver contact point in each slot; the fans should run. If so, immediately remove jumper wire.
Below is when the auxiliary fans are supposed to come on depending on the coolant temp. and or the refrigerant pressure. They will not come on until one or both readings are met.
As for the sound that the compressor makes is very difficult without hearing and seeing the compressor operate.
As for the AC compressor I have made another video with the AC turn on to hear the compressor
engage and making the whirring sound from inside the car. The compressor disengage and
the whirring noise went away as I turn off the AC. Could it be low refrigerant that made it work harder or
the bearing itself is about to go bad? There is one point last June the AC was blowing warm air and I refill
with a R134 can to the correct pressure.
thanks for any advice.
If so, the problem is with the blower motor or something is stuck in the blower cage.
I've tried turning ac dial #5 max before but with the dial control to direct the air to center cabin but the fan does not come on. Could there be another sensor must have gone bad to cause the fan not to come on at this mode? I will test on other mode later today and report.
Thanks,
Thanks,
Try this, turn the key to pos. #2 and turn the fan dial to 5. Do you hear any noise?
Update, turn key to pos. #2 and turn the fan dial to 5. I hear blower motor working to blow lots of air. Very strong. That is all. Am I suppose to expect other noise from this?.
