Coolant light/ heted seats fuse
Mercedes ML 270 cdi inspiration 2003
Ihave a Mercedes ML 270 cdi inspiration 2003. The Coolant light is on on the dash and the heated seats just flash on the dash. I am lead to believe that this is a fuse issue.
What exactly do I need to buy and where exactly is said fuse?
![](https://cimg9.ibsrv.net/gimg/www.mbworld.org-vbulletin/1011x414/2018_03_26_234348_c0a106be6c82cfa529d088c89b276a40a1a32f17.jpg)
![](https://cimg5.ibsrv.net/gimg/www.mbworld.org-vbulletin/791x444/fuse_battery_for_55_500_7b40ccc40e66ad3bba3e75bbef773e57b021a5a2.jpg)
Check the 100 or 75 amp fuse (green arrow) at the battery to see if it is blown.
If it is, then you will have to order one plus the special red plastic nut pictured. The red nut will break upon removal. They both must be ordered from a M/B dealer.
