Ml 320 power window
Ml 320 power window
Hello all,
I have a 2000 ml320, the back passage window won't go up on the center console, when I click the button to roll up the window, if I hold for a bit it starts going down instead of up, also when I press down on the opened window it slides down and if I pull, it goes up to where it previously was rolled down to, can this be the motor, or the center console switch?
Thank you!
Thank you!
No it's not the motor but if you keep holding the switch down you will need a motor.
The guides for the glass are dry. Move the window down & spray soapy water onto the side tracks of the glass. Move the window up. If it gets stuck move down and apply soapy water again and move window up.
Always wait a short time between up and down to give the motor time to cool off.
Awesome will try that, also forgot to mention that when I click the button to roll the window up it makes weird noises so can it be the window regulator? I'm afraid if I roll the window too far down it will get stuck all the way and I will have to go into the side door panel, but 1st I will try your advice, thank you very much.
