HELP! Removed ABS motor in 2001 ml320 but accidentally removed roller bearing too
Old Apr 21, 2018 | 02:40 PM
thepickle's Avatar
2001 ml320
Exclamation HELP! Removed ABS motor in 2001 ml320 but accidentally removed roller bearing too
I'm repairing the brushes and bearings on my ABS motor on my 2001 ML320. I removed the motor but accidentally removed the roller bearing with the motor shaft. Now the pump pins are pushed in and I'm unable to get them apart enough to replace the roller bearing. If I were to disconnect the break lines to the abs pump would that relieve pressure?
roller bearing
pump pins
Old Apr 22, 2018 | 08:24 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Here is the fix from another site.
http://www.benzworld.org/forums/w163...ml#post9611513
