Access to 1999 ML430 O2 sensor harness
Old May 22, 2018 | 03:41 PM
MikeC825's Avatar
ML430 1999
Am having trouble with Codes P0141 and P0161 after replacing both sensors. Does anyone know how to gain access to the harness and where it connect to?
I checked fuse F19........but not sure that feed the O2 heaters.
Wanted to check all connectors ............and possibly clean them or look for damage
Old May 23, 2018 | 03:51 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
The codes are for the rear O2 sensor, so there is a strong possibility that there has been water damage to the connector which is under the front carpet on the passenger side.
File Type: pdf
Old May 23, 2018 | 10:08 AM
MikeC825's Avatar
ML430 1999
I bet that is exactly the problem. I have been getting some water in the front passenger seat area. When I replaced the sensor I got some water out of the connector..............but sprayed with electrical cleaner the best I could from under the car .........
I will check this out asap Depending on how the harness goes it might be possible to affect the Bank 1 sensor too,
Thank you so much for the photos and memo..............I have a small compressor now and will blow out the sunroof drain
Old May 25, 2018 | 11:05 AM
MikeC825's Avatar
ML430 1999
You were spot on ! Found the well with quite a bit of water and the wires flooded. One wire came off when I removed the plug. Found it difficult to lift the rug so much, but cut an access hole ( sponge under rug soaked and dripping)
Going to the dealer for a new socket.
I blew out the sunroof drain..........But do you know if there are any other drains that go into the cabin?
Thanks for your help on this........saved me much time
