Insrument cluster plug question
Old Jun 29, 2018 | 04:19 PM
IgorE350's Avatar
01 ML55AMG 04 ML500 03 ML350 08 ML63AMG
2001 ML55AMG 4JGAB74E71A229618
Does anyone know what pin on Instrument cluster responsible for light on the cluster.
Iooks like not enough voltige going to the 4 bulbs that light the cluster up when i turn the headlights on. Bulbs are good, and dimmer knob looks like its working when i turn the knob it goes darker and lighter but i would say it lights up about %25 out of %100 does anyone know what it can be? or point me in a right direction. Thanks in advance
Old Jun 29, 2018 | 10:24 PM
IgorE350's Avatar
Originally Posted by Plutoe
Post your VIN!
Sorry i always forget to do that 4JGAB74E71A229618
Old Jul 1, 2018 | 05:27 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
You or someone else changed the illumination settings. Read pg. 80 in your owner's manual.
https://www.mbusa.com/mercedes/servi...owners_manuals
Old Jul 1, 2018 | 05:37 PM
IgorE350's Avatar
Hi, the Knob (1) that illustrated on page 80 is all the way to the right to the highest setting and bulbs are very dim you can barely see that bulbs are on when i turn the headlights on.
I am talking about the 4 bulbs that are inside of the Cluster that light it up. But Temperature millage and clock lights up good.
My headlights are not connected at the moment, but i dont think that would have anything to do with it?!
Unless i dont understand the page 80 and there is a programming procedure to it.
Why i wanted to know what pin on the plug controls the cluster lighting, wanted to measure it with a multi-meter see how many volts coming in up to it, if its possible
Old Jul 2, 2018 | 08:33 AM
For a 2002 model, it says the headlamps must be on. Try that.
Old Jul 3, 2018 | 06:23 PM
IgorE350's Avatar
Problem solved, pulled out the cluster turned out that the bulbs were 2w so went to the store got 5w bulbs put everything back, now its all good Thank you guys for help
