w163 diesel gearbox problems
Old 07-08-2018, 03:54 PM
RoelJoe's Avatar
w163
Hi, my gearbox is shifting not correctly all the time. Big delay after I push the gaspeddel. almost as if it has to think it over first. Could replacing the EGS computer help or should I search in a different direction?
Old 07-08-2018, 08:05 PM
Plutoe's Avatar
Received 1,020 Likes on 948 Posts
1999 E300TD
You need to diagnose the transmission control module to determine what is causing the issue---using the FUYA approach will not find and correct the issue!
Old 07-09-2018, 02:48 AM
RoelJoe's Avatar
w163
W163
Hi, I get the code p2600 and terminal 87.
I ll try to add the picture
Quick Reply: w163 diesel gearbox problems
