Transmission leak cant find
Old 09-19-2018, 12:38 PM
IgorE350's Avatar
01 ML55AMG 04 ML500 03 ML350 08 ML63AMG
Originally Posted by Maj. Dundee
I have no idea where that pin came from and you now have bigger problems with running the car without the drive shaft attached. There are only two pins in the parts diag., 70 and 140. You will just have to figure it out.
This is what happens when you want to tackle things that you have no experience with.
I didnt run the car without the shaft, it is jacked up, i just put it in neutral and back to park and that is when i hear the noise, so i shut off the car and it goes to park. cant have the experience if you dont do it and mess up few things.
Maybe if i install the shaft it will be ok ?! it should be here by the end of the week.
What can happen if i started the car and changed from park to drive or reverse without the shaft?
Old 09-20-2018, 12:39 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Originally Posted by IgorE350
I
Don't do it.
Old 09-20-2018, 08:40 PM
IgorE350's Avatar
Don't do it.
Wont do it again!
ill let you know whats gonna happen when i install the shaft.
Old 09-21-2018, 02:13 AM
Wont do it again!
Before anything, you must find where that pin came from.
Old 09-21-2018, 10:24 PM
IgorE350's Avatar
Got the driveshaft today, installed it and clicking noise went away i can sleep at night now.
The pin, when it fell out i pushed it back right-away, it fell out about 3 times. so i thought maybe that was the cause of the clicking noise, but i guess it was the shaft.. Now i know not to shift any gears without the shafts.
Now i guess ill find out if OEM pan gasket and that side seal will fix the leak, just have to paint the rear bumper and reinstall it and start driving.
Old 09-25-2018, 03:34 PM
smo0othride's Avatar
07 S600 Designo, 03 SL500, 03 ML500, 2016 E400
I have a mystery tranny leak as well. Wondering if it's the seal ring like yours. Glad I saw this post.
Old 09-25-2018, 10:09 PM
  #32
IgorE350's Avatar
Start from Electric plug on the front of the oil pan,usually its the first to go.
I didnt drive mine yet i am prepping the rear bumper to paint, probably will start driving next week and will let you know.
Old 10-15-2018, 06:55 PM
  #33
IgorE350's Avatar
After driving for few days no more leak, it was definitely that little O-ring on the driver side and i used OEM oil pan gasket. Very happy with the result, Thank you Mr Dundee!!!!
Quick Reply: Transmission leak cant find
