ML 430 tires...is it possible to get wider ones?
Guys,
Have ML430 stock wheels and would like to know, if possible if I can get wider tires on? Same rims.
I've seen an ML around town and really thought he had wider tires.
If so which would you suggest?
2015 C63 AMG 507
A bit wider...
I am running Eagle F-1's 295/45/ZR18's. Not much wider, but some. Thats about as wide as I think I can go unless I change rims I hear. Some of the other guys with bigger rims may be able to help. Yours are stock 18's?
You havee the stock 17" rims?
Originally posted by C-rod
l'm running with 285/60/18's...with no problems....the 18's look great on the ML....
a car that can't do the throttle reset.
Re: You havee the stock 17" rims?
Originally posted by andaya
285/60/18 will fit? on 17"?
Re: A bit wider...
