2002 ML320 Brake Lines
Old Oct 21, 2018 | 10:42 AM
TriscuiT's Avatar
2001 CLK430 Cabriolet, 2002 ML320
My girlfriend's car. She bought a new ride so the ML has been sitting undriven for a while. I want to start it and drive it around a bit and found the brake pedal going all the way to the floor. Uh oh. Looked underneath and found the puddle of brake fluid. Got down on the ground for a look and this is what I found. I am very grateful that I didn't "discover" this while driving around. I could use some assistance in identifying the proper part numbers for the two lines. I believe these are these are the rear brake lines but the picture is showing the lines view from the driver's side front wheel well. Practically right below the master cylinder. VIn = 4JGAB54E22A298593
I've replaced brake lines on my Dodge RAM 1500 but that was tall enough that I didn't need to use jacks to do the work. Am I just setting myself up for a nightmare if I try to replace these lines myself?.
Thanks.
Old Oct 21, 2018 | 03:47 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
You will have to buy them at the dealer. Make sure you ask them which is left and right. Also get a new line holder.
Old Oct 21, 2018 | 10:50 PM
TriscuiT's Avatar
Thank you, Major!
