02 ML500 Brake line rusted through - Advice?
I spoke to the dealership and they told me that I would most likely have to replace both lines since there is probably rust elsewhere, and to replace the lines it would be a major job where they would have to bend the lines to fit the vehicle which would run me upwards of $3k.
My question is, is there any other way I can go about resolving this issue? Has anyone here had this issue with their vehicle and gone a different route than changing both lines entirely? The vehicle is at 165k miles and is in otherwise good shape. I appreciate any advice you guys can throw my way.
Go to a dealership and order these two brake lines (approx. $85 ea.) and have a repair shop install them. Simply disconnect them at each end and maneuver them out.
The real problem is because the lines sit in plastic brackets (69-71-74 in above diagram) which collect water and snow which freezes over resulting in corrosion.
