2003 ML350 won't go in to gear
2003 Mercedes ML350
Hello guys i'm new with a weird problem. 4 weeks ago my car went into to a limp mode. The conductor plate was replaced and rhe code had to be reset before coming out off limp mode. It drives great until 2 day ago when the serpentine belt broke. I drove for a mile or so to get off the Highway when the car stopped. I managed to replaced to belt on the Highway with the help of a state trooper, started the car, put into drive but there is no shift in gear. I towed the car to a friend who is saying that I lost my transmission. The weird thing is, there are no check engine lights code at all on the scanner. The car will start, it will come out of park position to reverse, neutral and drive, but no shift or check engine lights and no codes. Please help. Thanks
If the car stopped while driving, it overheated the trans. fluid, is low on fluid or the shifter rod has detached from the trans.
Buy you own dipstick at a dealer or from Amazon or ebay.
