Help please with power steering question
Old Jan 15, 2019 | 07:39 PM
Shanc2's Avatar
2000 Mercedes ML320
Hi all! I have a question I am hoping someone can help me with. I just bought a 2000 ML320 and the belt came off while driving. After further inspection I see that I am missing 2 of the 3 bolts that hold the pump on and that is the problem as the pulley is wobbling. What I need to know is what size are the bolts I need? Can anyone help? Thank you in advance!!
Old Jan 16, 2019 | 06:18 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
There are four bolts that attach the pump to the timing case cover. These bolts must be purchased at the dealer. Do not use any other bolts.
You must remove the pump and check to see that none of these bolts broke off into the timing case cover.
File Type: pdf
Old Sep 15, 2019 | 11:03 PM
lvbatteryguy's Avatar
2015 C300 4matic, 2005 ML500 Special Edition
What are the part numbers for bolt #59 for the reservoir and bolt #29 for the bottom front of the pump?
Old Sep 16, 2019 | 06:47 AM
I answered your question in another post. Stop posting in different threads.
