ML500 Problem Left Indicator
Old Jul 2, 2019 | 05:39 AM
Larsrq's Avatar
Mercedes ML 500 2004
I have a 2004 ML500 with an odd problem. I noticed that my left backlight didn't work and it didn't help to replace it. I also noticed that the left front indicator (I think that what it is called) doesn't work. I change the fuse (F2) and both lamps started to work again. Now the same problem occured but it doesn't help to change the fuse. Have anyone experinced the same problem? And of course anyone got a solution?
Old Jul 2, 2019 | 10:20 AM
mihir_d's Avatar
2000 ML320 2006 SLK 350
Besides the fuse, there is also a left turn signal indicator relay. Have you tried replacing the relay?
Old Jul 2, 2019 | 10:25 AM
Larsrq's Avatar
Thanks will try that.
