no cables?
Old Jul 6, 2019 | 09:41 AM
justcoachb's Avatar
ML500, 2004, w163
no cables?
Everything points to the Brake Light Switch being bad but... when checked...there is none! no Brake Light Switch and no cables that would attach to it if it were there! ML500 2004, w163. also no lights on the dash ie ABS lights. what am I missing?
Old Jul 6, 2019 | 09:57 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
As of model year 2003, there is no brake light switch. The activation of the brake lights has now been moved to the brake booster and there is no repair for it.
What is your problem and or what is your question?
Old Jul 6, 2019 | 10:08 AM
justcoachb's Avatar
ML500, 2004, w163
ABS replacement done
My brakes went out on my 2004, ML500 w163, V8 at 228k miles. All the lights came on ABS ( BAS/ESP, ETS ABS AND BRAKE). Being high mileage I changed the brake booster, Master cylinder and the ABS mod. All the lights for ABS are off now but now will not shift into gear!
Old Jul 6, 2019 | 03:04 PM
Do you mean that you cannot shift it out of park?
Old Jul 6, 2019 | 03:43 PM
justcoachb's Avatar
ML500, 2004, w163
That is it! My brakes are still not responding with pressure as the pedal still goes to the floor but I think now I might just need to bleed the system.
Old Jul 6, 2019 | 09:30 PM
Of course you must bleed the system.
