2015 ML350 How to retract parking brake
MD wants $900.00 USD to replace just the rear and I can buy the OEM parts from the dealer and save almost $400.00.
Also, anyone know where else I can buy OEM pads and Rotors?
Use 13 mm socket remove retaining bolt
push out pins with a punch
Pads should pull out easily... If not.. I used a flat blade screwdriver to gently push them into the caliper.
The rear pads require putting the car into pad service mode as described here:
1. Turn the ignition to Position 1.
2. Make sure the mileage is displayed in the dash center window
3. Don't wait very long before accomplishing the next step: Push the far right "telephone accept call" button on the steering wheel, then push the "OK" button on the left and hold both down for 5 seconds or so.
4. The workshop menu should appear.
5. Scroll down to "Pad replacement" and push OK.
6. Choose OK for "Moving to fitting position"
Read more: https://mbworld.org/forums/m-class-w...#ixzz3JSpXdsvK
This will move the cylinder in the caliper far enough back to replace the pads...
wheel lug nut torque is 110 lbft
https://mbworld.org/forums/gl-class-...l#&gid=1&pid=2
