AAA module virgin dump
Old Sep 5, 2019 | 12:30 PM
G-tester's Avatar
ML320
Hello
On my old baby 2001 ML 320 has stoped working door remote control after the car battery was slowly discharged at airport parking lot I left for 6 months. The dealler say the AAA module needs to be changed for $1800 (parts and labor). I found good mb man who is specialized in programming things and he say it's common problem for this car (dump corruption) and he say I can repair this original AAA module but I don't have the virgin dump for this module
So if somebody has the virgin dump please upload one here. Thank you very much
Old Sep 10, 2019 | 11:22 PM
G-tester's Avatar
ML320
Originally Posted by Plutoe
Forget the sheep herder, find someone with DAS Xentry, the CFF file is on the system!!
Thank you for your answer. I've got china made c5 system. Can you guide me in a simple steps how to do it?
Thank you
Old Sep 11, 2019 | 05:26 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Did you replace the battery?
What does this mean..................."On my old baby 2001 ML 320 has stoped working door remote control". Does this mean the eng. starts but the only thing wrong is you cannot open or close the doors with the key fob?
If that is the case, the codes must be read, documented & cleared in the AAM.
Old Sep 11, 2019 | 08:15 AM
G-tester's Avatar
ML320
"""only wrong is you cannot open or close the doors with the key fob?"""
Yes, the only thing I can't open or close the doors with the key fob
Battery is fresh, remote tested at Autozone key fob tester
Thank you
Old Sep 11, 2019 | 09:50 AM
G-tester's Avatar
ML320
"""have you virginzed the applicable control module?"""
No, sir
How can I do virginizing the AAM ?
What the equipment I have to use?
Thank you
