Outside temp instrument light inop.
Are you sure the temp displays correctly?
Put a hair dryer to the temp sensor (located in the lower grille portion of the bumper) and see if the temp display changes. If not - time for a replacement.
OR
perhaps bad pixels.
Thanks, but no everything works as designed except the numerals are dark.
I recall in past others inquiring on the same issue.
You may wish to do search on the forum to see what has been reported and discussed.
GL.
